0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
#1419360 08/04/2021 4:37 AM
Moderated
Moderated
So we pulled two leaking freeze plugs out of our original 228 today. (1946 gmc ec152)
We then spent over an hour with the garden hose, flushing globs of dirt and rust from the block. It’s now running clean water. But when I reach a finger inside the freeze plug holes, I can feel what seems to be a rod or line, and it feels loose. I’m guessing oil line? Anyone have any idea what this might be? I’ve looked all over but can’t find any info online about the inside of a 228. Would appreciate any insight.
Big Bolt Forum Moderator
welcome to the site! You may not get an answer here, as this is the welcome centre forum, where folks introduce themselves and their truck. Not a lot of questions get answered here. Your question would be better answered in the engine shop area.
Mike
LDJones #1419378 08/04/2021 12:20 PM
Depending on where your poking it very well could be an oil line. You don’t want it to come loose. Our engine experts will be along soon.
LDJones #1419381 08/04/2021 12:45 PM
Shouldn't be any oil lines in a coolant passage, could be a loose wire someone lost in there while poking out dirt. Maybe they didn't pull the freeze plugs like you did and used wire to poke around and lost it.
There are bunches of fiber optic borescopes available on Ebay for ridiculously low prices that will let you take a detailed look inside that water jacket. One of the ones I use regularly has a 5MM probe 24" long, a right angle mirror attachment, and a variable intensity light built in that lets me look at the rifling of gun barrels all the way down to .22 caliber, and also look inside engine cylinders. It paid for itself the first time I used it!
I'm going to guess it's from the factory. Mild steel wires were commonly used to suspend and hold the cores in place when casting the block. These wires were "almost" always removed by the foundry before machining the block.
-David
1953 2-Ton GMC
I've had 5 GMC engines apart recently, and all had wire rods in them from the factory. Part of the casting process. No worries.
Joe
just retired and finally making headway on my project truck. 1940 GMC AC152.
Crusing in the Passing Lane
LD,
Make sure to use a rod or large wire to clean out drain and petcock holes of trash and rust that tends to accumulate there.
Ed
Have seen the same thing on several GMC inline 6 engines. The wire is about the same diameter as a coat hanger. As mentioned, probably used in making the sand core.
The oil line to the cylinder head on the GMC is external.
Best Regards...
LDJones Remember those sixties mopars that the coolant looked like chocolate milk?? That was from core wire in the block,
Moderated
Moderated
Thank you everyone, I’m feeling a little better about the mystery wires...
