0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
1940 -1946 running boards the same????[b][/b]
What model truck are you working on? That answer can then be checked for fender fit with a Master Parts Catalog.
Good question, I know the '40 had a shorter cab length (can see this at the firewall, 40 and maybe 41 had a step at the cowl). I'm sure someone will get you some measurements.
1946 1/2-Ton Chevy
Thank you fellas. Someone told me that 41-46 is about 1-2 inches longer on the front tip. Thanks again
You never told us what year and model truck you're asking about...that does make a difference!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'm working on a 1940 Chevy KD (3/4 ton long bed) pick-up. I picked up a pretty decent RH running board off a '41 to "46 truck to replace my battered and butchered '40 piece. The parts look just the same, but! So far it's setting in place to do a rough check, and the later part is definitely longer by at least an inch, at the front. The good news is that the front fender looks like it will bolt-up OK to the later 'board, but the outside lip of the running board extends forward into the wheel-well that 1" (+/-). The tip could be reshaped to to fit, but my thought was cutting the tip off my old beat-up running board and trimming the later board to weld the piece on would be less work, and should look original.
Please note, this is still just a mock-up so things could change during final fit-up. I believe the running board length difference would be the same on a short-bed, but I don't have a later short-bed running board to check.
Hope this information will be of use. Doug.
