3 members (CandoBrent, Guitplayer, 50Chevy3100), 155 guests, and 0 robots.
Topics128,106
Posts1,056,211
Members48,436
#1416656 07/11/2021 11:22 PM
Trying to line up a trans for my 46 project. Staying with a torque tube rear. But a few questions. Is there a dual master cylinder that bolts into the factory position on a 41-46 trans? If no then that opens up more possibilities for a donor trans and I will fab a mc bracket. Of all the possible trans options (40s/50s) , are all 4 speeds granny geared? My plan was/is an “original”-ish trans and a rear gear 3.55 conversion. Lots of 55+mph driving in my area.
Appreciate your time and input
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Ed, You can fab a bracket for a dual master fairly easily. I can shoot you some pictures of what I did if you want. Send me an email and I'll get back to you.
George
Something to think about is the master cylinder DOES NOT have to be in the factory position but can be moved back to an open area. The stock diameter 3/8 pedal to MC rod is good for about a foot longer and then larger needed if longer distance. I don't cut a new hole in the floor for MC access but just fill from underneath with a mirror and douche ball.
Evan
Thanks. George, I will pm my email to you... I have seen a lot of different relocation assemblies. my build is not. a restoration by any means. I was trying to keep as stock as I could, but if relocating makes more sense, so be it.
AFAIK, that's true. The Chevrolet 3-speed tranny is preferred as it has synchro on 2 and 3, and 1st is geared so low you hardly use it most of the time.
Ive been told that will work well, I had planned to do that...but now in up to my eyeballs in a T5 conversion, swapping out the torque tube, swapping in a '55 Series 2 axle, and will put 3.38:1 gears in it.
Good luck with your conversion, the r/p are the biggest factor, but to bring down RPM overall on the highway you need OD, IMO. Any pics of your truck?
Trad. Sorry no pics yet. I wouldn’t know which part to show. They are pretty much all on shelves anyway. Took 12 years, 1 move and a pandemic to get the chassis painted. Front end is being assembled now. So next is engine trans rear. Hopefully soon.
At least the pandemic did someone some good...you got your chassis painted and now getting the front end assembled... nanner
