| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 44 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 44 | Will be replacing one piece windshield rubber seal soon and I’ve never done one, yet alone replaced glass. I do have a “truck shop manual” for 48-51/52 supplement. It does explain how to replace, but my question actually is what/which recommended caulking or seal should be used when I go to put rubber seal and glass back on? I did buy some 3M strips in a box as they are about the size of a pencil and also in length. Thnx in advance. sambo | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Hi This is what I learned after doing a couple windshields myself (yes it’s possible to do alone but tricky and you should probably have help)
Install the rubber and glass without any compounds or else you will get it everywhere while fitting the rubber and glass If you need lubrications use a small amount of plain water or soapy water
After you get the rubber and glass in and dry off all the water mess if any mask off the exterior body and glass with good painters tape Use many small wedges and open up the rubber to metal and pump in RTV black silicone in the gap Massage it all down pulling out the spacer wedges and wipe off excess Repeat for the rubber to glass outside Then remove the masking And enjoy your water tight glass forever If done right you will never be able to push this glass out again The rubber will have to be cut to remove the glass
RTV black is good to fill rubber gaps if they shrink or crack It’s uV stable and very sticky and bonds well | | | | | Joined: Jul 2021 Posts: 44 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 44 | Well I got it installed and it sucked! Bought 1/4” nylon rope and fit it in the rubber channel. Used the Black rtv around rubber seal. Installed w another person and the rope did work to a point but tore the rubber in some area’s. Yep, it was a mess w the rtv everywhere. Used the Black rtv on the seal and glass side also. My only problem now are the top and bottom holes on the new seal do not light up with the inner and outer trim moldings in center of windshield. The two middle ones line up fine. Now to try and figure out on correcting this. “rubber seal/channel”= the new one piece windshield rubber seal. Thnx for the suggestion/s. | | |
