5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
#1418149 07/26/2021 12:15 AM
My charging system doesn’t seem to be working have a 52 Chevy truck 235 engine when the truck was 12 v when I got it had it rewired a couple of years ago and put an alternator on don’t remember the amps can run truck for a bit ( driveway idle)
Turn off than won’t start I keep the battery on a battery tender. I did notice a sticker on the battery with a 2013 battery
Could it be possible my truck isn’t charging the battery because it’s so old?
This is no longer fun
Definitely! Batteries have a limited lifespan, caused by the reactive material on the plates falling off the grids due to vibration and just plain old age. Try disabling the ignition so you can crank the engine for 15 seconds without it starting. After 15 seconds, while still cranking, the voltage measured at the battery posts should not drop below 9.6 volts. If it's below that, the battery either needs recharging or replacing. Even when using a battery tender regularly, I have to replace the battery in my Harley soft tail about every 2-3 years.
Voltage meter was reading 12.43 engine off engine running it was 12.39
I've had good luck with keeping batteries up to 7-9 years. But they are almost always on a battery tender. It is pretty obvious (to me) when it is time to trade it in for a new one because they won't hold a charge without the tender. (amongst other things). I have also had batteries that are so "dead" that the vehicle won't run even with jumper cables on it.
Another quality post.
Real Trucks Rattle
Curmudgeon
Curmudgeon
Every 9 years is about my experience as well.
I don't trust battery tenders that you leave on the battery all the time. In my area we have lightening storms that can zap them and the battery.
If the problem is not obvious (clean the battery cables etc.), I pull my battery and take it to my FLAPS. They hook it to a pass/fail load tester. Doesn't take long. If it fails buy a new one. If it passes and needs a charge, they put it to a charger that also determines the health of the battery (may take a couple hours). From this information I can determine if I have a problem with the charging system on my truck.
Some basic numbers.
A fully charged 12V battery should read 12.6-12.7V.
A charging system should put out ~13-14V. Some don't work at idle.
The alternator belt was a bit loose i pulled it back about 2 inches or so now it’s nice and snug p/s not making as much noise.
A new battery is next in the list but chasing a carburetor issue right now that I will go and check to make sure all the wires are tight from alternator to ignition switch.
Well didn’t get it out this summer hopefully for sure next summer.
Thanks to all for input.
