2 members (wilbur53, Otto Skorzeny), 39 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#141767 01/04/2005 2:15 AM
Does anyone happen to know the approximate weight of a C60 with flatbed? Or any C60 for that matter?
54 3100 with 235
62 flatbed dump C60 with 261
#141768 01/04/2005 2:26 AM
I guess I just answered my own question. I checked some old receipts from the dump and found one where they said I was 6,000 net and another where I was 5420 net. This is good. That will bring me under the 6000 lb weight fee when I make my truck legal.
54 3100 with 235
#141769 01/14/2005 2:40 PM
Junior Member
Junior Member
I weighed in at 8420 lbs both times I got weighed. I wonder what could make the 3000 lb difference?
[img]http://img.villagephotos.com/p/2004-10/846536/Exterior%20Drivers%20Side%201.JPG[/img]
'63 Chevy c60 dump
#141770 01/14/2005 4:39 PM
It seemed light to me too with big pickups running close to 6k lbs. Your truck looks pretty much the same except for the metal bed might be some extra weight. But 2500 lbs? Nobody else chimed in. I will look for some more old receipts from the dump.
[img]http://www.angelswest.com/_borders/dump1b.jpg[/img]
54 3100 with 235
#141771 01/14/2005 8:03 PM
Junior Member
Junior Member
Your bed floor is wood? If so and the fact that my sides are 10" I beam steel might very well make up 2500 lbs. The I beam sides had to be lifted on with a FEL but I have not real idea what they weigh. Let me know what you find out.
'63 Chevy c60 dump
#141772 01/14/2005 8:05 PM
Junior Member
Junior Member
I see what it is......it's the 31 extra cubic inches I have under the hood....yeah, that's worth a couple thousand pounds... grin :p
'63 Chevy c60 dump
#141773 01/14/2005 8:09 PM
Yes my floor is wood. And it is very light and mostly rotted out with some plywood over it. There is steel on the perimiter but not very big. The sides are wood too. Sounds like that might be it. That and maybe you had a full tank of gas, and I am real skinny... grin
54 3100 with 235
#141774 01/14/2005 9:29 PM
Junior Member
Junior Member
Well, I do try to keep the tank full and I am far from "real skinny" at 225 and my 50 lb english bulldog pup is usually with me. We keep a wonderen and we will make up 2000+ lbs quick.
[img]http://img.villagephotos.com/p/2004-10/846536/Elay080304.JPG[/img]
'63 Chevy c60 dump
#141775 01/15/2005 8:44 AM
Hydraulic Dump System will add a bunch of weight.
My 1960 Book shows C60 at 5310 to 5870 with out bed.
#141776 01/15/2005 7:23 PM
Interesting. I have a very heavy duty hydraulic dump system and also a very heavy after market front bumper. I doubt two guys could lift my bumper. So it would seem I should be a bit over 6K lbs with the bed, bumper and dump system with that figure.
54 3100 with 235
#141777 01/29/2005 2:03 AM
7
Apprentice
Apprentice
7 Offline
It sounds like mine needs a diet!! My 71 Gmc 5500 weights in at 10500. 292/4 speed with a 2 speed rear. 14' flatbed dump with a steel deck. cool
1971 GMC 5500(gone but will never forget), 1972 K20 with plow
