2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#1417461 07/20/2021 11:48 AM
Not quite sure, but is it better to adjust the rear brakes with the driveshaft removed? Seems like there is a lot of drag while you are rotating the tire for adjustment...…….. Maybe I am loco ??????????
AD Addict & Tinkerer
Never heard that one before. Just adjust them in until there almost locked up and back them off the number of clicks as specified in the Shop Manual. Mine for my ‘52 3100 is 14 clicks.
Phil
Project Journals
Stovebolt Gallery Forum
Are you talking about the same animal? I always thought Bendix started in '53 so a '55 would have Bendix and the '52 would have Huck. Am I wrong about this?
But I'd adjust according to the manual.
Bendix brakes started in '51 on the 3100's. Huck brakes hung on a bit longer in the heavier trucks (3/4 ton and up, IIRC).
My ‘52 3100 has bendix brakes. dance
Phil
Project Journals
On Bendix brakes, regardless of what vehicle they're on, the conventional procedure has always been to tighten the adjuster to get a "firm drag" (not locked up) and back the star wheel off one turn. That's usually 10 clicks. Once you start backing off, ignore any slight drag- - - -the bottom of the assembly "floats", and it's not uncommon to get a little scuffing noise even with the right adjustment. The brake shoes self-center every time the brakes are applied. On self-adjusting brakes with the fine tooth star wheel, adjust for a firm drag, release the one-way ratchet with a thin screwdriver, and back off 20 clicks.
I am confused - a condition that has become more frequent as I get older and more addled.
ORIGINAL POSTER:What make, year, size truck are you referring to?
Do you have original-equipment-style brake parts?
The 54/55st Shop Manual instructions are slightly different from most of the above instructions.
I have followed the Shop Manual instructions for decades with no problems.
