0 members (), 129 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#1417491 07/20/2021 4:24 PM
I have a 1949 3800 with the long bed. When I got the truck it was completely missing an exhaust system, including all the hangers.
I got a reproduction exhaust system from Waldrons.
I found a NOS muffler bracket.
I have never installed an exhaust before - I have it roughly installed now but I don’t know what to use for all the brackets. I can’t find original ones and that’s ok - what after market brackets have people here used? Any suggestions?
JP3800 #1417502 07/20/2021 5:49 PM
Get some standard exhaust pipe clamps and some 1/8" x1" bar stock. Attach the clamp to the exhaust pipe in the vicinity of a hole in the frame and bend the bar stock to fit from the clamp to the hole, drill a hole to bolt the bar stock to the frame and weld the bar to the clamp.
JP3800 #1417519 07/20/2021 7:28 PM
Ok - that is perfect. Seems so simple but when you’ve never done it, it’s hard to know.
JP3800 #1417595 07/21/2021 5:45 AM
Fox Offline
https://www.summitracing.com/parts/wlk-36516
I used these Walkers on my C10. They are a great price, and the 6 I bought are very solid. I will be getting these for my 50 1/2 ton as well. You won’t be disappointed, but you do have to weld them onto the pipe.
Bolt on- no, welding required.
Quality- YES.
Easy install- that’s relative.
Alternatively, similar to Kevin’s suggestion, I have also used these:
https://www.autozone.com/emission-c...ilt-universal-tail-pipe-hanger/59032_0_0
Bolt on- yes
Quality- depends on brand?
Easy install-yes
However, the rubber tore on my 1 ton and I had to replace the hangers. I haven’t got around to it, but I might use the walkers I mentioned above on my 1 ton in the future.
Get a quality hanger, whatever you do, and you’ll be good!
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Moderated by  Dusty53
