0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 13 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 13 | After getting my 1957 235 head back from the machine shop I sprayed on Eastman paint prep to get the, what I thought was an, oil film off before painting. The more I sprayed and brushed the more metal colored stuff kept coming off. After spaying two cans of the acetone I'm getting close to it being clean. I'm very new to this, my first head from a machine shop, so I'm wondering if this is some kind of clear coat or cast iron colored paint on it. I'm now hoping I didn't screw this up. Anyone know what's this is about, or words of wisdom? thanks, Paul | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I would have called the machine shop before I started removing any coating.
| | | | | Joined: Jun 2021 Posts: 13 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 13 | Unfortunately I didn't know there was any coating on it except oil film before I hosed it down with acetone. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Best advice is to call them and ask  what they used. There is no way we could guess  what another person does. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | I would say they painted it with cast iron gray enamel, as long as you have it stripped and the remaining is not lifting from the iron you should be fine just hitting it again with the engine paint of your choice.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Lots of machine shops use this stuff: https://goodson.com/products/lb-1-cast-iron-spray-paintIt's a quick drying flat finish paint that looks like cast iron and keeps reconditioned heads, blocks, and such from rusting in storage. You can paint over it with any good quality high temp engine enamel. jerry
