| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | I just finished installing the drag link rebuild kit for my 1950 chev 3100. In order to get the cotter pin through the end caps I had to use a long extention on the ratchet to get the end cap in. Now the drag link ball seem way to tight as I can not move it in any direction by hand. I have not used any grease yet which may be my problem? Should it be these tight on both the axle end and pitman arm end? | | | | | Joined: May 2015 Posts: 11,117 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,117 | Are you sure you got it assembled correctly? The rebuild kit I used had a couple different spacers. One spacer had a longer stem which might restrict compression of he spring.
You should have pre-greased the parts on assembly, but even grease wouldn't help if it's overtightened (especially if the balls are worn).
The service manual says:
"...tighten plug snugly to remove all end play of ball.
2. Back off screw plug one complete turn plus amount necessary to insert cotter pin and lock adjustment.
Ball joints must be tight enough to prevent end play and yet loose enough to allow free movement. Be sure sockets have ample lubrication."
Granted, "snugly" is a pretty vague value, but they have to be able to move.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,225 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,225 | I've always run it up tight with a ratchet (compressing the tension spring) and then back it off to the next cotter pin hole. You should never put a breaker bar or impact gun on it as you will damage something. Mike B
| | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | Okay back to the drawing board. Kevin there is the longer spacer on the one side so I could switch that to a shorter one. I will also start with liberal use of grease and see what happens. I think I might try taking everything out and just run the cap through to make sure all the threads are good. But clearly I have something wrong | | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | Okay got it. Mine only has the one cotter pin hole on each end on both sides. On one side I went with the shorter spacer and on the other end I notif you looked through one end of the cotter pin hole to the other side it was nor perfectly aligned. So I enlarged thenhole slightly on one side and all is good!!! | | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | I just read in the tech section of the forum a tip for rebuilding a drag link that the cups are not the same diameter as the ball which created tight steering so the tip is to lap the cups so it loosens a bit. I will probably wait until I resemble my truck (frame still bare) but if I find hard steering that’s what I will do as I find the movement now is far from lose but at least I can move around with some effort | | | | | Joined: Aug 2019 Posts: 172 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 172 | Wrong part: Turns out I had the wrong ball joints: Ordered new ones from The Filling Station and all is as it should be | | | | | Joined: Feb 2004 Posts: 29,840 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,840 | Back when that type of drag link was in general use, it was pretty common practice to drill an extra cotter pin hole in the link so a finer adjustment could be made on the spring preload. 90 degrees of turn instead of 180 gave us a better range of adjustment. jerry
