5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#141691 01/29/2005 2:21 AM
7
Apprentice
Apprentice
7 Offline
I have a 54 6400 dump for a possible restoration project. I would like to make this a work/show truck that can be driven to shows out of state or haul 4 tons of stone from the quarry. What kind of frame or driveline swaps are being done out there that work well. My mechanical abilities are unlimited and time is not a factor. This also might be worth not doing. My 71 GMC 5500 might be a better choice to restore for this. Any thoughts?? Thanks in advance. cool
1971 GMC 5500(gone but will never forget), 1972 K20 with plow
#141692 01/29/2005 4:01 AM
This is one of my favorites: wingedexpress\'s truck
I have a '51 4400 and a '52 6400 and intend to make one road worthy by using later P30 suspension stuff. I'd show you, but I haven't done any of it yet...
#141693 01/30/2005 2:53 AM
7
Apprentice
Apprentice
7 Offline
Thanks.That looks like a p30 chassis. That will give me one heck of a tow vehicle!! Any other thoughts out there?
#141694 01/31/2005 5:57 PM
I put a 292 out of a 70 chevy 2 ton along with the transmission into a 6100 with the two speed rear end. Every thing worked out great. the top speed is about 75 with carb and header mods. It will haul anything. My uncles used to haul stone and gravel out of the quarries in Okla. and preferred the 292 to any other gas engine.
#141695 01/31/2005 7:14 PM
Hello 71bigbolt
My truck is actually on a 1953 2 ton frame with late model front and rear and my old body thrown on top.I will try to update my pics soon as i'm almost ready to test drive it around the yard.A late model rearend and straight axle front with disk brakes would also work good .
#141696 02/02/2005 12:26 AM
7
Apprentice
Apprentice
7 Offline
Redcoat, how well did that 292 fit into your 6100? That would work fine for me considering I have a spare 292 in the barn (and my 5500 with a 292 isnt shy about about hauling 6 tons of material eek ).I know the motor mounts are offset but can I use the orignial tranny? Is that 2 speed orignial in yours? If not what is out of? Thanks again.
