5 members (Hawkman, Peggy M, Otto Skorzeny, BC59, 1 invisible), 178 guests, and 3 robots.
Topics128,078
Posts1,056,057
Members48,433
#1416623 07/11/2021 5:56 PM
Hello all, several years ago, I swapped out the old vacuum wiper motor for an electric wiper motor in my 54 Chevy five window 3100. The problem I have is, the wipers don't park like they should, they park with the wipers in an upright position, any suggestions as to why? Did I install it incorrectly or??? Thanks in advance...Clint
Curmudgeon
Curmudgeon
You didn't say if you have the original or reproduction electrical wiper motor.
The original has to be adjusted on the bench (removed from truck).
There is an inside park setting screw to adjust.
Let me know if you need this procedure.
Attached is info on a reproduction electrical wiper motor (may not be exactly like yours).
This information should have been included with the other documentation in your kit.
I don't have this motor so I'm sorry I can't recommend an angle and park setting.
I would suggest you contact the business you purchased from and get better information.
Okay thank you for the response, I'm not sure if the electric unit is original or not, I will have to look next weekend.
Curmudgeon
Curmudgeon
Look at the wiper control knob on the dash.
The original electrical motor used the same knob and mechanical cable as the vacuum motor.
The kit has a new knob and electrical switch (see picture).
e-mailed the manual to the factory wiper motor to the address shown in your profile. There is definitely a park function to the motor. The manual will make it more clear. If it is a factory electric wiper motor, there will be two holes in the top of the dash that are wiper motor mount holes.
Curmudgeon
Curmudgeon
Yes, he would have had to drill the two dash holes if he used the original stabilizing bracket.
Not an easy task. That's why I think he installed a kit.
Moderated by  ndkid275, Phak1
