4 members (55shaker, Phak1, D B Cooper, msmall), 57 guests, and 1 robot.
Topics128,095
Posts1,056,069
Members48,433
#1415478 07/01/2021 1:36 AM
Can anybody tell me what this number means? It’s stamped on a plate in the center of the drip edge (that’s what I call it) on the firewall.
Numbered Plate
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
Anybody out there? You guys are giving me a “being ignored complex”. smile
I haven’t gotten any replies to this message, nor in the ‘55-‘59 photo gallery. frown
1957 Chevy 3200
Daily Driver
Follow in the DITY
Posting the same question in two separate forums is considered poor Stovebolt etiquette. You are not being ignored, possibly no one knows. BTW the Gallery is not the proper place for questions (note the Gallery rules). If someone knows the answer to DES57’s riddle, please post before his head explodes! ohwell
Maybe a military or fleet ID??
I didn’t post the question twice! Only on this General<Truck Talk. I was just feeling left out on the Photo Gallery because nobody commented on my post of my truck and write-up.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Good thought 68Ironhead. If true, not every truck would have one. I’ll have to do some “under the hood” checks at the next car/truck show I attend.
1957 Chevy 3200
Daily Driver
Follow in the DITY
DES57, sorry about that. Your post made it sound like you had asked in both places. I see what you are saying now. Not everyone gets responses right away on their Gallery posts. Nice looking truck for sure.
I've never seen that tag before...none of my trucks have it.
The factory could have added it to a Fleet contract to keep track of the number of truck made against the total number owed (just a guess).
Do you see any signs that your truck was fleet owned?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
Need to see a wider shot of firewall. My guess is that was stamped as part of the stamping tool for that piece and has nothing to do with the trucks "usage" or customer or military. Any tracking of the truck could be done by VIN/Serno. or other riv on plate.
I’ve not seen anything indicating fleet owned, but I’m fairly knew at this stuff. I just find it strange to be a plate attached versus just a number stamped into existing sheet metal.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Here’s a wider shot of firewall on my 57 3200.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Could it be a part/inventory number from the assembly plant?
Sir Searchalot
Sir Searchalot
I see now you say "stamped on a plate" and "a plate attached". Didn't realize that and I can't see that it is a separate plate. So you are saying there is a plate that is riveted, welded, screwed, glued or tattooed to the "so called "drip edge"??????? Not stamped into the drip edge/lip/firewall rib????????
I was thinking that the tool/die that stamped out the edge/rib......also at the same time, in the same stroke, stamped a flat spot and numbers.
Yes, it’s a separate plate that appears to be spot welded on the left end. I can’t get my old face close enough to see the weld on the other end.
1957 Chevy 3200
Daily Driver
Follow in the DITY
Here’s the wider firewall picture.
1957 Chevy 3200
Daily Driver
Follow in the DITY
I just looked at my 56 3200, and no numbers stamped or otherwise added on the drip edge. I think that is a good name for the metal piece as it seems its purpose is to keep water that runs down the firewall from possibly getting to the numerous holes and then running into the cab.
1956 Chevy 3200, 235 w/3 speed
Thank you LeeD! I’m guessing it could be a tag for the cab number while being built in a specific factory, and prior to being installed on a vehicle with a serial number.
1957 Chevy 3200
Daily Driver
Follow in the DITY
I wonder if it was a special order Fleet Color paint code...any signs of the original factory color?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
A little remnant of a blue seatbelt and the paint code on the door pillar plate says blue.
1957 Chevy 3200
Daily Driver
Follow in the DITY
You have Stock 1957 seat belts?
What's the paint code number?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I attached a picture of the door frame plate with 764 paint code.
1957 Chevy 3200
Daily Driver
Follow in the DITY
1957 Chevrolet Paint Code 764 = Brewster Green, which is very close in color to Forest Green which was VERY popular truck color in the early/mid 50's.
So, that blows a hole in thinking it was a special fleet paint code...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
....Forest Green which was VERY popular truck color in the early/mid 50's.
Forester Green was the DEFAULT color for most of the AD series trucks (47-52). If you didn't ask for something else, you got a Forester Green truck.
But yes, that Brewster Green was a standard available color, nothing special about it. IIRC, Brewster Green was a standard color for the earlier trucks and resurrected for the late 50's.
Per Page 75 on this document it may even have been the default color (being at the top of the list of solid colors available).
