2 members (Hotrod Lincoln, 1 invisible),
137
Mod | | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I have a 53 Chevy 3600. I am having a heck of a time trying to find the front wheel bearing upgrade for the 3600 3/4 ton trucks. Can anyone help me out?
Elmo. | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | Why "upgrade" a design that has worked well for over 75 years? The myth that tapered roller bearings are somehow better than ball bearings doesn't have much proof behind the fantasy. If you simply must make a change just for the sake of following the crowd, find one of the progressive size charts that all bearing manufacturers publish and do some measuring of the original bearings. If you can find an outer bearing race("cup")that will fit the bore of the hub, a good machinist can make an adapter sleeve to make the "cone" fit the spindle. You'll also need to find a grease seal that can be fitted to the hub, and have a sleeve made for the seal lip to ride on, since the original equipment ball bearing has the seal surface built into it. Jerry
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I upgraded my 49 150’s wheel bearings by packing them with new grease from the latest century. 72 years old and look absolutely perfect 👌. I regularly cruise at 70mph for hours with zero issues. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | If what I have in my truck is the way to go, I will just keep what I have. If it ain't broke, I'm not gonna change anything. It's always good to know what's good or bad. And I thank you both for the information.
Elmo | | | | | Joined: Dec 2020 Posts: 104 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 104 | I looked into that as well on my '53 3600 with no success my bearings an races were in great shape so that's what is going back in. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | If I have to replace a bad set of ball bearings, I buy roller bearings as replacements The new ball bearings are priced a bit high. The last two trucks I changed out, I went ahead and bought the hub/bearing/seal kit. They are nice, and all you need to do is pack the bearings and install the hubs. No hammering out old races required.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Hotrod Fully agree with your take on bearings,need to leave em alone mine are over 70 yrs. old now . run good !! | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Two years ago had to do some work on an Audi, the owner wanted the wheel bearings changed. Perfect ball bearings and it was a newer auto. The Allied Forces found late in WWII that if we concentrated on the ball bearing factories in Germany we could bring them to their knees. My 1940 Plymouth truck has perfect ball bearings that I don't believe were ever changed according to the original owner. Nuff said. Doc.
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Roller bearings must be cheaper to produce than ball bearings. I have to think chopping a long rod into pieces is easier than making a perfect sphere. I've always thought that's the reason behind the shift to rollers.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | All the bearing information we need to know is available in books, on the Internet and in classrooms in engineering schools. The different type bearings are engineered for a purpose (or application). It requires the effort to study. Be skeptical about the media hype, magazines and the "hot new" stuff you read about. You can get sidetracked into buying something you don't need or worse installing something inferior.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | I've always been just a bit suspicious of anyone who proposes to solve all my problems by selling me something. There might be a possibility he has an ulterior motive, like transferring my money to his pocket, for instance! Jerry
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | A lot of big truck “hub assemblies” that are replaced as a unit are still ball bearings. Front of my passat is ball bearings and i have replaced them once or mabey one side twice but its got 400k miles on them. My 49 is still on its originals but it did have low mileage when i bought it. I dont think a lot of those old trucks really drove all that many miles before being replaced or parked indefinitely. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I think that the only real difference between the bearings is that ball bearings are noisier as they get older. Ron | | |
