1 members (baldeagle),
91
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 22 | Howdy Folks. Just installed a Tremec 600 in my 51 3100 and now my speedo cable is about 2" to short. Is there an over the counter fix here? Has anyone else dealt with this God forbidden, life altering dilemma? | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Not really. You should be able to locate a longer one fairly easily. Remove yours, measure and add 10 inches not 2. | | | | | Joined: Feb 2020 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 22 | | | | | | Joined: Feb 2020 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 22 | FYI, I got a 73" cable from Jegs that is the perfect length and works perfect. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Don't let this life altering experience derail you. God forbidding, you will be better from it. Trust me.
