2 members (baldeagle, ranchojuan), 37 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1416022 07/06/2021 12:04 AM
Howdy Folks.
Just installed a Tremec 600 in my 51 3100 and now my speedo cable is about 2" to short. Is there an over the counter fix here? Has anyone else dealt with this God forbidden, life altering dilemma?
Bodini #1416030 07/06/2021 12:42 AM
Not really. You should be able to locate a longer one fairly easily. Remove yours, measure and add 10 inches not 2.
Bodini #1416098 07/06/2021 5:54 PM
You might find something from a 4x4 website, Does the Tremec have a different connector? I personally would prefer a single cable, but an extension might be more economical. A quick web search revealed an extension: https://www.dakotadigital.com/index...40/category_id=311/mode=prod/prd1140.htm
https://www.summitracing.com/search/part-type/speedometer-cable-adapters?N=transmission-type%3Atremec-tko-600
or a new longer cable:
https://transmissioncenter.net/product-tag/speedometer-cables/?product-category=gm
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Bodini #1416234 07/07/2021 4:59 PM
Thank you guys.
Bodini #1417194 07/16/2021 3:09 PM
FYI, I got a 73" cable from Jegs that is the perfect length and works perfect.
Bodini #1417418 07/19/2021 8:36 PM
Don't let this life altering experience derail you. God forbidding, you will be better from it. Trust me.
1946 GMC Project
"Back-in-the-day Restore"
