0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | I have forgot, can I use 1962 thru 1966 GM condensers on 6 volt systems? Doc.
| | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | The condenser doesn't care about voltage, Doc. Some of the ones I've seen that were saved from the 50s and 60s have dried out and no longer work, however. The insides of these were just foil wrapped around a dielectric film or gel. Time is the worst enemy...the stuff gets brittle and then fails to do the job. You might get a good handheld multimeter and check the capacitance. If it isn't at ~.22uF, then don't use that one. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Jon is too modest to promote his condenser upgrade unit but it is not age sensitive and works well. We have used one in a 58 Chevy 283 and a 85 Ford Ranger with a 302 V8; both run well but you will have to check back in a year on longevity. Make that 90 days on the Ranger which is how long the "off shore" ones were lasting. PM Jon.
Evan
