2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | What is everyone using for the paint/color on the intake and exhaust manifolds on a 216 CID? Thanks. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Top right near your user name, click on the magnifying glass. Click on Advanced Forum Search. In the field that says Keyword Search Terms enter with quotation marks: "manifold paint" Where it says Date Range, Newer than, you want to delete the number in the first box, then click the down arrows in the next box to the right, then select the blank. Where it says Older than enter 1 in the box, then to the right click the down arrow and select days. At the bottom click on Search Forums.
Go pour yourself some coffee and come back and enjoy the reading. This is one of those topics that generates a ton of opinions. The good and the bad of, if you do it his way, then this will happen. Personal preference.
I like natural cast iron rust. It's easiest to maintain.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | The manifolds weren't fully painted but did get overspray on them. Any overspray burnt off in short order. Unpainted natural finish is considered to be correct for judging purposes.
| | | | | Joined: Sep 2010 Posts: 2,334 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,334 | The engine in my truck was orange ,but most say should be grey .I had a parts truck that also had some remnants of orange also it was a 51.I decided to change to grey and I am halfway there .I had my manifolds off so I used graphite in a aresol for the exhaust and grey for the intake.the grey I used being from Canada I used court grey armour coat from Canadian tire .We will see how it holds up .Kevin | | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | "Stove polish" (beeswax and carbon powder) works better than paint on exhaust manifolds. It turns them a deep black that won't burn off like paint, and it's easy to reapply occasionally with just a cotton cloth to a cold manifold. Wear gloves if you don't want your fingertips to get stained! Jerry
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I use Caylx manifold dressing. Its probably nothing more than what HRL's "stove polish" is made of. I use The dark gray engine paint available from thefillingstation.com on the rest of the engine and the intake manifold. The Caylx lasts a good year. If it needs to be touched up, it is just a matter of wiping more on the manifold. Then you get another year of a nice looking manifold.
| | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Ok thank you everyone for your answers/suggestions. I think I'll go with grey on the intake and "cast" on the exhaust. I'm not going for concourse judging, I just want it to look somewhat period correct. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | I like the idea of stove polish. I used barbeque paint but it is beginning to rust. | | |
