| | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 197 1950 Chevy 3100 216 3 Speed. | | 1950 Chevy 3100 216 3 Speed. Joined: Jun 2020 Posts: 197 | I have a 3 speed trans and a 216 cu engine in my 1950 Chevy 3100. For as long as I can remember I have had to double clutch when going from 1st to 2nd and from 2nd to 3rd. If I double clutch I can easily transition from gear to gear without grinding gears like I was just learning to drive. I learned to drive in this truck in 1977, and at that time shifting from gear to gear was seamless. I don't have any desire to go away from the 3 speed, so what are my options?
Darren Current Project - 1950 3100 5 Window with a rebuilt 216 and 3 speed trans
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Adjust the clutch so the synchronizers can do their job properly. The clutch disc should be released completely from the flywheel during shifts. If a clutch adjustment doesn't help, you've got a worn out synchronizer and/or bearings in the transmission. Jerry
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Or you're using the wrong gear lube in the transmission... Mike B  | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I used to double clutch my 4-speed to prevent grinding. After years of that, I found that holding the clutch pedal down once and just pausing midway through the shift (is there a detent?) stopped the grinding. My left knee is going to last twice as long as it would have. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Pausing in neutral works on upshifts- - - -downshifts still require speed-matching the gears, with or without the clutch. Jerry
