| | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | I'm putting together my vent windows for my 65c10. What kind of adhesive should I use to attach the felt strip to the vent pivot arm? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I am not quiet sure which part of the assembly you are referring to. The dividing bar has a channel (felt lined) that the window runs up and down in. The vent window has a molded rubber piece. If you are referring to the dividing bar, I used a 3m adhesive from any FLAPs. I pivot for the vent window is inside the door. But if you are to this stage you are getting close to finish line. cheers. | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | You are correct in your assumption. When I ordered parts they called it the vent pivot arm. I thought of the 3m adhesive. Just wanted to make sure. Thanks 👠| | |
