2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 13 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 13 | After examining the 8 external head bolts (ones outside the valve cover) taken out to remove the head from my 1957 235 I notice that one is different. It is the farthest to the back on the driver's side and has a thicker (taller) head and the shank is the same diameter all the way from the head to the threads which is unlike the others that are tapered slightly to a bit smaller diameter about 3/8" below the head to the threads. Does anyone know if this is normal or has someone replaced that head bolt with something different than stock? Thanks in advance for help. Paul | | |
