5 members (1955 1 Series, 49nut, rfs56trk, Eisenholtz, tclederman), 88 guests, and 0 robots.
Topics128,046
Posts1,055,618
#1414513 06/22/2021 10:41 AM
Hi All, I have a 51 3800 with a 58 235ci motor and I don't know what the four speed is so I can replace the clutch. It does a pto on it. How do I decode the numbers on it? Thank you in advance, Gerry Lee
Go to the Novak site it is probably a Muncie sm 420 .if you search the numbers it should also tell the year but the Novak site shows the differences as well .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
R Online: Content
It's good to know what year/model transmission you have but that is not necessarily going to determine what clutch you need. It could possibly have a 10" or 11" clutch depending on which flywheel it has. The only way to get the correct clutch is to remove it and match it up or have it rebuilt.
Fred
Thanks for your input. It is a sm420 but it has a 10 3/4" clutch and now to try and locate one! Thanks again, Gerry
