1 members (RBs36), 172 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#1413576 06/12/2021 12:13 AM
Has anyone had good luck using the reproduction door latches for a 1950? I have to replace mine and I have heard some of them are junk.
1950 4400
I have yet heard of a positive experience with reproduction door latches.
Perhaps those who have had a good experience with them have not been motivated to share this.
Curmudgeon
Curmudgeon
I too read about experiences of others and I decided to see if I could fix what I had.
Believe it or not, I started by rebuilding my door hinges. Drilling-out and installing oversized hinge pins.
I finally got the doors to align decently.
Replaced the weak springs that allowed the door handles to sag.
The last problem was that the door latching was not consistent.
Sometimes I had to slam the door and sometimes the door would pop open by itself.
If you look at the picture (I used new repop hinges for example), the arrows show the pawl or ratchet edge.
These are nice and sharp. Mine were rounded off. Nothing there to catch the teeth.
I used fine wire in my MIG welder to fill in this edge. Dremel tool and file to shape the profile.
It worked better that I expected. I still don't like the GM design but this solution was cost effective.
Insomniac
Insomniac
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
I know about the Altman latches but I can’t justify spending that much on latches for a big bolt, 1/2 ton maybe but not a 4400.
1950 4400
Were you able to find all the springs for the rebuild? I can only find the large one that keeps the handle from sagging.
1950 4400
Curmudgeon
Curmudgeon
Most common to replace is the handle return spring.
A quick search found the rotor and safety springs here: (https://www.ebay.com/itm/164553784922).
Even with the good Altman latches, if the door hinges are worn out so too will be the new latches.
1950 4400
Long before there was an Altman bear claw kit we got them from junkyards. Usually cost about $10 for a pair. On projects with a mechanical release we put the latch in the door and the striker in the pillar. On ones with electric release we did just the opposite; latch in pillar and striker on door. With the latch stationary one could run an emergency release cable out the bottom of the pillar in case battery went dead.
Latch in door:
[img]https://i.postimg.cc/5j6jctHy/bear-claw-latches-001.jpg[/img]
Striker on pillar:
[img]https://i.postimg.cc/sQtzCs8G/bear-claw-latches-002.jpg[/img]
Latch in pillar:
[img]https://i.postimg.cc/dkTMBg1s/bear-claw-latches-008.jpg[/img]
Striker on door:
[img]https://i.postimg.cc/VdWxDqYC/bear-claw-latches-009.jpg[/img]
Evan
Insomniac
Insomniac
What donor car(s) did you choose?
Gord πŸ‡¨πŸ‡¦
