7 members (Flint48, Red75bronco, 78buckshot, Leo, wvstovebolt, TUTS 59, 1 invisible), 88 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
Hello, I'm restoring my 1950 Chevy Pickup. I have removed everything I can in order to strip rust, epoxy primer, and top coat as appropriate.
My question, what do I use for the areas I can't reach? The cab corners are a good example. I can't get down there to remove the rust. Not only that put putting a coat of anything in there will be challenging.
Any suggestions would be greatly appreciated.
Mike
You can use a hand pump up sprayer (garden sprayer) and fill it with Evap-O-Rust. The wand will allow you to reach into most nooks and crannies. Good luck.
β€˜65 Chevy Biscayne (Emily)
β€˜39 Dodge Business Coupe (Clarence)
β€œI fought the law and the law won" now I are a retired one!
Sir Searchalot
Sir Searchalot
Depends on how bad the rust is. As Martin says, there are products to encapsulate it or change it's ability to spread. Those usually require the loose rust to be scraped/wire wheeled, etc.
If it is rot out rust, you must cut out whatever you have to cut out. That's what patch panels are for.
Should have a little room if you take the back of the seat out .products like rust mort are suppose to neutralize the rust and are like water so they can be sprayed .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
That is if it is not rot like bartamos explained
"The Journey"
Follow in the DITY
Thanks for the input guys. I'll clean up what I can, and apply one of those products.
Insomniac
Insomniac
We used to have a company here that had a huge dip tank. They could take the whole cab and frame and submerse it in some sort of chemical that removed everything (grease, paint, rust), ready for epoxy primer. I don't see them around anymore - probably closed due to environmental regulations.
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
I tried a product similar to evapo rust works ok but would take a lot to do big pieces ,it also is environment friendly but only takes so much off then needs to be replaced .I guess you could plug up the drain hole in cab corner and pour it in then drain out after it does it’s work .They also have a gel that might work as well .
"The Journey"
Follow in the DITY
Evaporust does have a gel, but I haven't had good success when I tried it. It has to stay moist to work and then needs to be rinsed off.
Like bartamos said, cut out the rotted stuff that has to be replaced, then deal with the rest. My solution was to get the cab sandblasted. Even that doesn't get to all the nooks and crannies. You do the best you can with whatever you have available.
Pressure washer to clean the areas of loose rusr and dirt, then spray the areas with Ospho. After 24 hours, hit it again with the pressure washer to remove the white crusty residue which is a byproduct of the conversion of iron oxide (rust) to iron phosphate (inert coating which is now rust free). Let ti dry and paint it if you can get it in there. If you can't, don't obsess about it.
You are trying to slow the rust process down, not eliminate it for 40 years.
I used this in a few places. It was easy to use. Effective? Ask me in a few years. Made me feel better, anyway.
https://www.eastwood.com/eastwood-internal-frame-coating-14oz-aerosol.html
Dennis
40 Chevy 1/2 ton
