0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1413882 06/14/2021 7:22 PM
Custom Title
Custom Title
Hey guys. I've put about 700 miles on my rebuilt and mildly hot rodded '54 235 now. I just wanted to check that my oil pressure is ok. It runs at 35 psi all the time so I'm guessing that's where the relief valve is set. It hardly drops from there, if at all, at hot idle. This isn't surprising since all the clearances are tight, but personally, I'd like to see more at speed, maybe 45-ish. Or am I good where it is? If it should be increased, how exactly do I do that? Last, I just stumbled across Tom Langdon's write-up about preventing air leakage into the oil pump. How concerned should I really be about this?
Thanks!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Moderator, Electrical Bay
It is up to you, but it sounds fine to me. I wouldn't be concerned at all.
~ Jon
I have had both 216's and 235's and I have always referred to these old and rebuilt engines as slush bucket oil pressure. 35 Lbs. is a great o/p. I'm sure anyone would love that kind of o/p. Maybe the other Stovebolt folks can add to this. 45 lbs. is a dream to most of us. Doc.
Curmudgeon
Curmudgeon
I would buy an add-on oil pressure gauge and run a new oil line to verify.
I recall a similar situation where sludge or trash was in the old line and gauge which caused a consistent reading.
R&R the relief valve spring will do that if the pump output, bearing condition, and oil viscosity are all good, but it's not needed.
You already have the largest factory pump.
Tom’s article was about keeping air out of the pump to prevent hydraulic lifters from ticking. Some hydraulic cam motors develop a tick you can never seem to get rid of. Air in the lifters via the oil pump is one of a number of possibilities for causing that. If you are running mechanical lifters this is not a concern. If running hydraulic lifters, this is only a concern if you have a lifter tapping, the tapping bothers you, and you can’t adjust it out.
Pressure, I think you want to double check that pressure with another mechanical gauge just to be certain, as recommended above. A steady oil pressure is just not a feature of these motors, lol. But hey, stranger things can happen I suppose!
Mike
Any oil pressure at all indicates that the pump is producing more oil volume than the engine needs. Extra pressure just wastes horsepower that could be used to drive the vehicle. If you're that concerned about it, put a couple of flat washers behind the roll pin that secures the pressure relief spring into the pump housing. Just don't do like one of my competitors on the dirt track did- - - -he shimmed the spring so tight that the relief valve couldn't move, and the first time he revved the engine up the oil filter burst.
Southtowns27 You are doing great with oil pressure. If you increase it it'll wanna "wash" your bearings that is oil flow is too high-not necessary. Had a noise in my 235 oil pressure would hit it and shut it up,installed -.002 new bearings is quiet keeps 30 lb. gauge pegged !
The local oil pressure at the journal/bearing interface is a function of the pump (gauge, relief spring, "nominal") pressure multiplied by the wiping speed of the 2 surfaces.
The stovebolt's 2.3125" rod journal has 115.6% of the local pressure of a 2.000" (Gen-3 L6) journal at the same RPM.
Custom Title
Custom Title
Thanks, guys. I'll leave her be...
49 Chevy 3600
65 Chevy K10
