8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#1413439 06/10/2021 4:36 PM
Grandpas truck: bought sometime in the 70's or 80's by my grandpa, to haul wood out of the bush with to the cabin.. started life as a 51 1 ton, thats what the frame is still now. he did a cab swap out of a 53? i believe. then during that frame off he did they also put in a 62? blueflame 236? box was originally wood, he had a custom built steel box made with hydraulic dump. he did the whole interior in the red along with the resto... current issues i have with the truck: brakes, they are garbage cant find anywhere to get 1 ton adjusters/ hardware.. the hydraulic piston leaks, so thatll have to get rebuilt, basic maintaince hasnt been done in way to long..
it needs new rims and rims, the bolt pattern is same as a dmax, 8 on 6.5 so we bought dmax rims off a 01, but i have no idea if the hub size is the same or not along with the offset. other then that just minor stuff, speedo doesnt work, says 93,000 has never been rolled over, it is the 4sp with trans ebrake, we do also have a spare one laying around one of the shops as well, need to get the fluid changed on the one thats in it now though, rear pinion seal too is leaking, most of the brake lines/MC are newer.
jrich #1413728 06/13/2021 2:53 PM
62401
Welcome to our site! Nice truck! Please post all of this in our Gallery section -- it would go nicely in there.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
jrich #1416017 07/05/2021 10:54 PM
Moderated
Moderated
Absolutely live that seat upholstery pattern!
jrich #1416622 07/11/2021 5:33 PM
Nice looking truck, my 1 Ton also came from Southern Sask originally purchased in Weyburn.
Not sure if the front brake cyls are still available from Lordco but when I replace mine they were off the shelf. The Master cyl and rear cyls I had to order out of the US The Filling Station 1-800-841-6622. You could try KMS Tools 1-877-655-8665 or The Old Car Center 1-604-888-4412 in Langley B.C.
Good luck with the finding rims and tires it's been a real pain getting something that fits over the drums without rubbing on the tie rods up front.
Doyle
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Moderated by  Dusty53
