6 members (cmayna, Hugh63c10, Cosmo, TUTS 59, oldieoldie, greenie-reddy), 128 guests, and 4 robots.
Topics128,184
Posts1,057,195
Members48,465
I see a square plug on the rear differential, I'm guessing that's how I drain it. My questions are:
1. What oil type goes in it
2. Is there a fill cap on the top somewhere?
Thanks!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
AD Addict & Tinkerer
The plug your seeing is for filling. You drain it by loosening and prying open the bottom of the cover. Once drained, remover the cover, clean out the gunk on the bottom. Inspect or replace the gasket , then reinstall the cover.
Fill to the bottom of the fill hole. I use 90 weight multi-purpose gear lubricant. If you have a posi rear I believe you will also need some type of additive.
Phil
Project Journals
Stovebolt Gallery Forum
You MAY be able to drain the differential by removing the lowest bolt from the cover. That works on a 47-55.1 1/2 ton. If that works, there's no need to mess with the cover gasket.
Thanks, guys!
Isn't there some letter/number combo on the differential to tell me if it's a posi? Or do I have to just jack the thing up? Dang Frankenstein projects grin
That would certainly be the easiest way to tell. If you can find some numbers on the rear, post them and I’m sure our collective will be able to tell you what you have.
Phil
Project Journals
Will do- thanks!
I ran out and quickly checked the sides of the carrier, no numbers found yet but on the left (driver) side are 3 horizontal lines, and on the right (passenger) side are 3 vertical lines. I'm going to look at the base of it within the hour.
Can't see the numbers. I'll have to wait until after work when I can get some grungies on.
