2 members (ronsway, Hotrod Lincoln), 126 guests, and 2 robots.
Topics128,079
Posts1,056,312
Members48,442
#1412643 06/04/2021 4:24 PM
I will be picking this beauty up next week. I was wondering if anyone has used adapters to be able to put 22.5 alcoas on it? I searched but didnt find much
https://imagizer.imageshack.com/img924/1916/SU7tZ6.jpg
3B Offline
Hy wickedinhere, welcome, if your new 50 series has a 7000 lb front axle you could swap hubs and drums from a 60 series (same wheel bearings). depending on which rear axle your truck has you could do the same swap with the rear hubs and drums, that would give you ten stud on 11 1/4" bolt circle, same as the semi's have, good luck with your truck
That truck is in amazing condition and you can never go wrong with that color! I have a 69 C60 in the same configuration but with Dayton rims. I like the adapter in the 5th wheel to pull a gooseneck too.
Thanks guys
