I have just purchased a 1966 c60 with a 292 engine,4 speed with 2 speed axle, 16 foot grain bed with hyd. lift. This is an Oklahoma wheat truck, which means it has been rode hard and put up wet . Normally used for a month out of the year, with very little extra care, just enough to keep it running. Last registered in 2009. OK, this is my first big truck and know little of its workings that do not apply to smaller trucks. I'm looking for parts numbers for the following, formed top radiator hose, Pcv valve and grommet, and the name and part number for the hose that runs from the oil bath air cleaner to the valve cover. Just the valve and grommet are what I need. Does the hydra vac system take special hoses?
Are seat springs available?
I'm sure I will be looking for more unknown parts later.
No I have no pictures at this time. Any trouble spots I should look for? Thanks
