1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
I need a cross reference for the rear brake return spring on my 1955 chevy 6400 first series. Chevrolet part number 3694516. I've tried all the usual parts sources, NAPA lists them but can no longer get them. Priced having one made but unless I order 50 or more it's too expensive.
3B Offline
Hy Chevy's till I d, if you search big bolts for brake spring subjects you'll find the springs have not been available for quite some time, one of our members had some made and now has some for sale, hope that helps.
Noonan is the seller.
Thanks guys
How do I look up a member in order to message them
Menu bar at the top. Click on “Member List” type in the name and hit the search button. You can then click on the member name and the option to PM will be there.
