| | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I'm reassembling the rear wheel cyls. on my 2 ton and I have aluminum and steel pistons. Which would be best? I'm guessing the steel, but I don't know about the corrosion factor. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chris's 46/515, My vote (if that counts for anything) is for aluminum. Brake fluid is hydroscopic and the moisture it will attract could rust your ferrous parts together. The more your truck sits the more likely you'll encounter problems. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chris's 46/515 I put slicon grease (ignition) on aluminum pistons,then if they set I don't think they stick as bad. Can't use anti-seize has oil in it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The "steel" ones are called sintered iron. Much better then the aluminum pistons. If the unit sits for about 2 or more years the alum. ones will be stuck. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | 35 years ago i had an old car the pistons were sticking. I read in hemmings motor news that people were using silcone brake fluid in old cars. So i honed out all 4 cylinders installed new rubber cups bleed the system to try to get all the new fluid in. I still have that car sometimes it maybe a year or 2 between driving it and the brakes have never locked up again still works good like when i did 35 years ago. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 29tons Iuse ignition grease a lot because it does'nt hurt the plastic on so much stuff today,maybe that break fluid is the silicone oil I have been hunting. Have always used DOT break fluid. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | WrenchbenderRet Haden't noticed much difference,my garage apron slopes so pull up there and see if truck rolls back easily. If it does your OK. My 72 ton would't roll back right front like a heating stove,swapped in a used caliper fixed it !! | | |
