8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 15 | Trying to separate intake and exhaust manifold before assembly, '54 Chevy 235. 2 bolts on bottom of exhaust are bigger than 1/2" but smaller than 9/16". Cleaned up w/ wire wheel on drill, tried file that I use to sharpen mower blades and won't even scratch it. OK - split the diff, look for 17/32 socket - no one stocks it. Anyone know what size they are? | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Mine seem to be 9/16" but corroded down a bit in size. Maybe some metric socket will fit it perfectly. Not that they were metric in '54, of course.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Those bolt heads are rusty/worn 9/16", since the bolt diameter is 3/8" on the clamp bolts. 3/8" bolts have 9/16" heads. If a 9/16" 6 point socket won't grab the wrench flats, try using a cheap 12 point 13MM socket that you don't mind damaging, and hammer it on. 13MM is slightly bigger than 1/2". Soak the threads with KROIL or some other penetrating oil, and/or heat them before wrenching. Jerry
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | `...then drill out the broken bolt in the box, and snap off an easyout in the hole in the bolt. Then see how far you can shotput that manifold across the shop and break something valuable with it.  (I laugh so that I won't cry.) You don't have to follow what I usually do with these heat treated fasteners, but don't come unglued if they brake. It happens. Heat the box with a torch. Soak in Kroil. hit the top of the bolt with a hammer to help the Kroil get into the threads. Next day, carefully turn the bolt clockwise, feeling for the slightest bit of movement, then stop! Then try to back it out. I don't know why tightening a bolt breaks it free better than loosening, but it does. If you don't get any movement when you carefully tighten it. Start from the beginning and do it all over.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Someone told me to try to tighten a stuck bolt or nut first because that was the last direction the bolt or nut was turned. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | I have a set of Craftsman bolt extractors that are spiral hex that grab a rounded head as you turn it to loosen it. They might work on rusted heads. Here's a link to various similar extractors. LinkIf you want to try a metric socket, I would try a 14 mm first, as 13 is REALLY close to 1/2 inch (0.512"). 14mm is 0.5512" while 9/16 is 0.5625". Whatever you try would definitely have to be 6-point rather than 12 point.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,478 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,478 | Heat the box with a torch. Soak in Kroil. hit the top of the bolt with a hammer to help the Kroil get into the threads. Next day, carefully turn the bolt clockwise, feeling for the slightest bit of movement, then stop! Then try to back it out. I don't know why tightening a bolt breaks it free better than loosening, but it does. If you don't get any movement when you carefully tighten it. Start from the beginning and do it all over. 52Carl is right on, except he missed on very important tool. PATIENCE! In this case an abundance of patience is required and of course a 6 point socket. Don’t attempt it with a 12 point as you will round it out. Heat the area surrounding the bolt threads to two - three hundred degrees then douse it in your favorite penetrant. I like Kroil, followed by PB Blaster. Now tap the head of the bolt. Try to remove but don’t get too forceful. More penetrant. Let it cool, try to remove but again, don’t get to forceful. Douse it in penetrant and let it sit a day. Repeat! If after three or four days of doing this, cut the head of the bolt so you can separate the two manifolds. This will leave you with the end of the stud sticking out. Find a nut that just fits over the stud and weld it on. The heat of welding usually breaks the rust bond. Douse and repeat the above procedure. Good luck!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52 Carl You dont weld onto them ?? Once you break something hard off in there weld is about the onlt choice !! | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | 52 Carl You dont weld onto them ?? Once you break something hard off in there weld is about the onlt choice !! I guess you missed the part about the throwing of the part across the shop and breaking something else. I suppose I would look for the aforementioned thrown-with-extreme-prejudice part some time later and try something else such as welding. Perhaps my description of how I operate can be held as an example as to how not to proceed when the going gets tough.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Something that seems to work better at loosening seized/rusty threads than oil is paraffin- - - - -the oldtime sealing wax that's available in big blocks at the canning supply department of most grocery stores, or candle wax. Heat a stuck bolt or nut until it's almost red, and apply the wax liberally. I use chassis grease, beeswax (toilet bowl seal rings) and paraffin to make cast bullet lube, so I always have a couple of boxes of paraffin blocks around the gunsmith shop. Jerry
| | | | | Joined: Apr 2014 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 15 | Got it off - thanks for all the ideas. Used 14mm socket (a bit loose), several days of Liquid Wrench + tapping, finally heat from MAP gas torch and tightening a bit before backing it out. | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 |
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,478 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,478 | Good to hear!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | OK, I guess it would be advisable to listen to some of what I recommend. Just pay attention for when I start to go off the rails, exhibiting intemperance.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52 Carl Saw that part about fireing stuff across the shop do it here too !! I usully weld a lever on problem bolts then heat the casting carefully,once it moves just walk it along if it squeeks little more heat if lever hitscut it off put on endo so you can vise grip it. Have several manifolds saved that way. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 52 carl On one thats able to be drilled thru have taken the sharp torch and blown the center out of it let it cool then unscrew. | | |
