| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Hi guys, Again thanks for all your help on this build. Sheesh, I cant seem to find anyone that knows the size, let alone has them. Does anyone here know? :can't look:
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Most likely thery're 3/8-16, grade 8, around 3/4" or 1" long. Places like Tractor Supply or Fastenal should have them on the shelf. You could also use Allen socket head bolts- - - -all the above are available by the thousands on Ebay. "This ain't rocket surgery!" Jerry
| | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | I believe there are lock washers on those too
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Ahh yes.. good point guys.
| | | | | Joined: Jul 2018 Posts: 71 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 71 | Sorry, I wasn't paying attention the first time around and posted the wrong link. Use the following link and your search is over.... https://www.jegs.com/p/ARP/ARP-Pressure-Plate-Bolts/744904/10002/-1?&productId=744904&Tab=SKU&year=1966&make=CHEVROLET&model=C10+PICKUP&submodel=BASE&engine=L6+%28+4.8L+%2F+292+%29 http://www.allensfasteners.com/sear...5ytPs8AIVlD6tBh2NKgBAEAAYASAAEgIzUvD_BwE
1966 K20 long bed
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Good luck threading those bolts listed in the first link into a flywheel- - - - -they're for attaching an automatic transmission flex plate to the crankshaft. The ARP 3/8-16 X 3/4" or 1" flange bolts would probably work, WITHOUT a lock washer. Use blue LocTite instead. Jerry
| | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | While we're at it.. I read there was no condernable difference between an automatic flywheel and a manual.. I am bolting a manual to this flywheel.. It says auto written on it.. I got no clue if it matters.. everything seems to match up fine..
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | A flex plate for an automatic transmission is a thin piece of steel plate with a starter ring gear welded to it. The torque converter is bolted to it and provides the inertia to keep the crankshaft spinning smoothly. Standard shift flywheels are about an inch thick, and weigh in at 30-40 pounds plus the rotating weight of the clutch and pressure plate, so whomever told you they're the same has his "head up and locked" as we used to say in the USAF! On an internally-balanced engine like an inline six, there won't be any difference in the balance of a flex plate or a flywheel. Jerry
| | | | | Joined: Jul 2018 Posts: 71 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 71 | Just for general parts interchange info between a 230 / 250 and a 292, you might find this link useful... http://www.sonic.net/tfoot/pigpen/292fan.htm
1966 K20 long bed
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 38 1.5 ton I see this is old...you know those pressure plate bolts have an area with no threads that supports the pressure plate and goes into a recess in the flywheel bolt hole. they are not just ordinary bolts from your hardware store. On a high winder you may recieve a visit from your pressure plate. | | | | | Joined: Sep 2009 Posts: 6,012 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,012 | 38 1.5 ton, Here is a link with a picture of the pressure plate bolts with "no threads that supports the pressure plate..." noted by fixite7. https://www.holley.com/products/fas...rivetrain/pressure_plate_bolts/parts/910Hope it is of some help. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | GDads51 A friend who was no mechanic bolted up his pressure plate with just soft bolts,up at the gas station he opened the hood and raced that engine,blew the pressure plate down,well his girlfriend was sitting right above it no one hurt but for weeks after that you would see bolts and springs laying around there.So gotta watch out !! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | HotRodLincoln Using the bolts you recomended may require some surgury if that pressure plate blows out of there !!! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | GDads51 On your wife's 66 chevelle does it happen to be 327 with a Carter AVS (air valve secondary) carburetor ?? I had a plain jane 275 horse 4-speed that was the best sounding piece ever. With an exposed air filter it sounded just as tuff as any quadra-jet.Wore that whole outfit out,eventually put it in an AD 52 pickup never sounded as good again something about that flat hood I guess. | | | | | Joined: Sep 2009 Posts: 6,012 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,012 | fixite7, Read your note and will send you a PM to keep from swerving his post/thread any further off course.  Suffice it to say we have "some" similar ownership history my friend.
| | | | | Joined: Sep 2009 Posts: 6,012 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,012 | 38 1.5 ton, Any updates on your clutch/flywheel project?  Hope you've been able to find what you need.
