5 members (Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Woodcmiami, 1 invisible), 145 guests, and 7 robots.
Topics128,077
Posts1,056,031
Members48,433
Hello,
I disassembled the engine hood three years ago. Have some one pictures how must i fix the engine hood at the cab so does it works?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
If you're talking about the hinges, here's a picture of the page from the Factory Assembly Manual that shows the hood hinge. Also a picture of the hood with the hinge attached from my truck.
If you don't already have a Factory Assembly Manual, and still have work to do on your truck, you should probably get one. They're available from Amazon or eBay.
Hope that helps.
Thank you!
AD Addict & Tinkerer
Here is s link to a thread about adjusting a front end clip that all starts with the proper alignment of the hood. It was written by a fellow ‘bolter, 52carl, and has been followed by many other ‘bolters with success.
https://www.stovebolt.com/ubbthread...ort-installed-1954-3600.html#Post1406026
Hope this helps!
Phil
Project Journals
Stovebolt Gallery Forum
