1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I just wanted to share that the PG tranny in my panel has been sitting for who knows how long. When I drained it for the first time, the fluid came out like strawberry milk, which means it had gotten water in it at some point along the way. After a few four letter words, I was off to pick up some new fluid.
I'd read that type F fluid, which was developed for Ford tranny's, was actually good to put in a PG, as it has a thicker viscosity to it (to manage the Ford heat). After reading that, and knowing my PG may already be scrap, I said what the hey and bought 4 qts of Type F to put into my PG.
I added it, and on my first run, I could feel the tranny starting to come back to life. I could feel the response when I shifted from Park to Reverse, and it was also detecting Drive right away. I went slowly around the block, and I am pretty sure it stayed in low/first, but that was fine- it was moving, so I was happy.
On my 2nd and third runs that took place last week, I stepped it up a little, and I could feel it shifting from low to drive! Again, I may have been going 30mph max, but, that tranny is doing its job!
I'm going to do another flush and fill, but I wanted to share that the type F is working just fine, if any of you are looking for validation on the urban legend as to whether or not the type change would be OK. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | In the mid-1960's Ford started using a dark brown (almost black) colored friction material on their automatic transmission clutches. The stuff was hard as woodpecker lips, and without using a fluid with a lot of friction enhancers, the clutches would slip. GM used a softer, tan-colored clutch material that would grab OK without the extra friction additives. Pretty soon, the drag racers learned that using Type F fluid in a GM trans instead of Dexron gave it a much more positive shift, especially when combined with a "shift kit". It also had a habit of causing the GM clutch material to de-bond from the discs it was glued onto, but they didn't care- - - -the occasional hand-grenaded transmission was just part of playing the game. TCI (Torque Converters Incorporated) sold thousands of gallons of Type F to the racers by putting it in their own containers and advertising it as "high performance" transmission fluid. Good marketing to the P.T. Barnum crowd! Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have a Hudson with the wet clutch and have read in several forums that Type F can be used in place of the pricey Hudsonite. Going to do a flush with the recommended kerosene and then give the Type F a try.
Evan
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Hard to find kerosene in Dallas and the last I bought was about $7 per gallon. Hope it is easier to get up your way, Evan.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Try the local airport- - - - -Jet engines consume huge volumes of "aviation kerosene". They might be persuaded to part with a couple of quarts- - - -and they might even give it to you!
That Hudson wet clutch is a bunch of cork pucks a little bigger than a quarter, bonded to a steel disc. The fluid keeps the cork from drying out. Jerry
| | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | That Hudson wet clutch is a bunch of cork pucks a little bigger than a quarter, bonded to a steel disc. The fluid keeps the cork from drying out. Jerry Wonder how many millenials would know that. I didn't even know that, am I'm nowhere near a millenial  | | |
