8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY), 126 guests, and 1 robot.
Topics128,109
Posts1,056,253
Members48,437
#1410843 05/21/2021 11:34 PM
Does anyone remember cork borers used in the ancient days in chemistry labs? Glass tubing could be inserted into the hole and the corks could be stuck in a flask for some purpose. The borers have a tapered cutting edge.
Well, I used a cork borer to cut the perfect bolt holes for my home-made carb gasket. Made me smile.
I used sharpened brass cartridge cases as gasket cutters, at least until I found a very nice set of gasket punches from MAC tools (used) on Ebay for a killer price. The trick for getting a clean-cut hole when using a gasket punch is to back up the piece youre cutting with something like a block of red oak or hard maple.
Fox Offline
I’d never thought about using old brass.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
AD Addict & Tinkerer
I used to punch 1/8” gaskets (1-2” holes) for manhole covers and very large valves and the end grain on hardwood worked much better than using the side of a plank.
Phil
Project Journals
Stovebolt Gallery Forum
Twist, don't hammer, or chuck the case in a variable-speed drill motor. Thin brass doesn't survive much pounding.
Moderator
Moderator
2 Offline
Just to add to Jerry's thoughts.
Make sure the primer in the shell casing is also spent.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
If you're really good at aiming, "wadcutter" target bullets make nice clean holes, and the do it very quickly!
smile
Moderator, Electrical Bay
I bought a metal cutting hole punch on Amazon for use on brass. Turns out it also does well on plastic, leather, gasket material, etc. Punches sizes up to about 3/8" neat as you can want. Think it was about $30. Makes the work go pretty quickly, also because there is a small pin set in the dead center of each punch piece. You just put that in the center of what you're punching and there you go.
~ Jon
I have a set of those cork borer tools I pulled out of the trash can, use 'em all the time. Didn't get the sharpener though.
Harold Wilson
41 Chevy 3/4 Ton
I have the sharpener....somewhere.
When I say something like that, it essentially means, "i do not have one of those."
Me saying that I "have" something in my busy shop should be considered to be a commission of fraud. Gross negligent fraud.
I need to stick with something like, "I don't know. We can look around for one in here for a couple of days..."
Carburetion specialist
Arch punch sets can be expensive, but occasionally will find used ones on ebay. If I remember correctly, mine goes to 1 1/2 inches.
A revolving leather punch does a really nice job on holes up to maybe 3/16.
And for hand-cutting gaskets, a pair of curved-tipped finger-nail scissors really makes cutting curved surfaces much easier.
Jon.
The Carburetor Shop
Wally/Montana Use a 2 oz. ball-pein gasket hammer a lot,hard to find 2 oz. quality hammer !!
Moderated by  MNSmith
