7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible), 77 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
I have come to notice 3 holes over the right barn door of my '57 Panel that were filled in. Any thoughts on what they may have been for? I'm guessing maybe there was once a light mounted up there for police/ambulance/fire co. other?
What's odd is, they are only on the right side. Pics attached.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
AD Addict & Tinkerer
Is there limited access behind these holes? If so, could be holes left over from pulling a dent with a slide hammer.
Phil
Project Journals
Stovebolt Gallery Forum
Ooh, good callout! I did not even think of that.
I was looking at this pic that I have of a paddy wagon from the time, but no light on the back:
I just found 2 examples of fire rescue panels, and both have lights on the back. Hmmmmmm..
Your holes don’t appear to be concentric nor centered on on the rear.
Phil
Project Journals
Good points. I think you may have nailed it with the bodywork theory.
If it were a ight, there would be a big(ger) hole somewhere for wires.
Also a very good point, thank you.
