8 members (KEVINSKI , mick53 , 55shaker , Peggy M , Gdads51 , Hanks custodian , MickeyP , 1 invisible),
148
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,089
Posts1,056,137
Members48,435
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Does anyone have a picture of a correct upper hood support brace that goes over the radiator ? I don’t know if it’s a hood support problem or a radiator problem…. Thanks, Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
Couple of pics from my 40
The filler spout looks high. Does it clear the hood? How high is your filling spout from the top of the radiator? Thanks, Mike
Hood fit pretty well and cleared without any issues. I can measure the distance for you tomorrow
Mike I do not know if the radiator mounting is the same for 1940 vs 1946, but the later year model needs to have the fasteners, rubber pads and springs and the “V” support rod adjusted just right in order to get the hood to fit correctly. In looking at your photo, my guess is the radiator mounts may need some adjustments?
The radiator sits in a frame which controls the height of the radiator. There is virtually no adjustment for the radiator within the frame. The frame/front clip, sits on two thin rubber pads which could be adjusted to align the hood somewhat but that won’t effect the clearance of the radiator fill spout/cap and the hood. Mike
1.5 inches on the short side and just about 2 inches on the long side.
Thanks… much appreciated. Mike
