I drove my '57 Panel for the second time today. This time, I had the speedo hooked up.
I could tell immediately that the odometer is working as expected, but I'm not seeing the speedo lift up. I had put dry lube in it a few weeks ago, and when I spun it by hand, it reacted (as did the odometer). But this time, I saw no activity on the speedo.
I have to admit, I probably wasn't going any faster than 20 (for fear that things would start falling off of the truck, lol), but I was expecting to see some minor activity at least.
Based on the fact that the odometer works, and the speedo does not, does that mean I am looking at a new speedo gear and/or rebuild? Weird that one would work, but the other does not.
Hmm. The odometer is gear driven and so if it is working then we know the cable is turning and that tells us the transmission gear is probably ok. The speedometer needle relies on magnetism to make it spin, but if the needle jumps a bit when the rear bit is spun by hand that implies you do have magnetism. Make certain the needle isn't binding on the speedometer glass or somewhere on the dial. It won't take much to disable it even though the magnetic part is spinning...
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
Thanks!
I'm hoping to tear into it today to see if I can determine what the problem is.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
While I'm looking into someone repairing this speedo for me, I have to ask: has anyone ever heard of the magnets inside of these things losing their magnetic properties over time? I fully understand that the gauge is 60 years old, but I'm thinking once a magnet, always a magnet. Am I wrong on that?
Mine still works and it is a year older than yours. You should be able to see the speedometer move when you spin the back where the pin plugs into. The magnet is a close fit inside the ‘cup’ that actually moves your needle and it should be very easy to move the needle and cup parts.
Lee
Thanks, Lee- I can move the needle by hand and its weight returns it back to 0, but it does nothing while driving (even though the odometer moves while driving).
