8 members (Materman, cmayna, Rusted Nut, Stovebolt48, Hugh63c10, RoadsScholar, moparguy, SNOYL),
100
Mod | | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 45 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 45 | Good morning everyone.
My engine is the 235ci in my 54 Australian built Chev truck. My manual indicates I require AC 43 44 or 45 spark plugs.
Where have people been getting your plugs from?
I am looking for original style non tapered seat as at the moment I am using a modern plug which is a tapered seat.
Are you just getting them N.O.S from Ebay or is there a business that can supply these?
Thank you John. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I just bought R45's at our local NAPA store. Don't know where to get them down there.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jul 2011 Posts: 45 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 45 | I might have to get them from Ebay.
R43NTSE
Would these be what you have? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Tapered seat spark plugs in an application intended for gasketed plugs do not dissipate heat properly. They will burn out very quickly, and the overheated plug tips might cause detonation in the combustion chamber that will blow holes in the pistons. Original equipment "AC" plugs are not the same as "AC-Delco" which is a product made offshore- - - -not from the USA. I'd recommend an equivalent heat range plug from Champion, Bosch, or maybe NGK if you can find something other than AC-Delco in the proper gasket design and heat range. Jerry
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Rock Auto lets you show prices in AUD, so I suppose that means they will ship parts to you. Rock Auto I have placed orders with them before and have had good service.
Gord π¨π¦ ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Champion j12yc or j14yc will do the trick if you canβt find ac. If you need a resister version to calm down radio noise, just add an βrβ in front of those numbers. They are the correct extended plug with the gaskets. I have run those plugs in my motors for nearly 45 years in both stock motors and modified motors.
J12y, j13y and j14y are the older obsolete numbers but they turn up at flea markets and eBay. Theses will also work perfectly.
Mike
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | "R" prefix plugs also have another important function besides limiting radio frequency interference- - - - -they prevent erosion of the contacts inside the distributor cap and the rotor tip by limiting the current flow across those contacts. A "hot blue spark" that was once the ideal situation is also the equivalent of an arc welder where distributor cap conductors are concerned. Resistor plugs and/or wires prevent damage to critical components while still providing plenty of fire to light off the fuel mixture. "Wire" conductors for ignition systems went obsolete over 50 years ago. Jerry
