7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible), 114 guests, and 1 robot.
Topics128,094
Posts1,056,060
Members48,433
#1410025 05/15/2021 10:30 PM
Good morning everyone.
My engine is the 235ci in my 54 Australian built Chev truck.
My manual indicates I require AC 43 44 or 45 spark plugs.
Where have people been getting your plugs from?
I am looking for original style non tapered seat as at the moment I am using a modern plug which is a tapered seat.
Are you just getting them N.O.S from Ebay or is there a business that can supply these?
Thank you
John.
Dawso #1410028 05/15/2021 11:16 PM
W Online: Content
I just bought R45's at our local NAPA store. Don't know where to get them down there.
Dawso #1410031 05/16/2021 12:46 AM
I might have to get them from Ebay.
R43NTSE
Would these be what you have?
Dawso #1410034 05/16/2021 1:18 AM
Tapered seat spark plugs in an application intended for gasketed plugs do not dissipate heat properly. They will burn out very quickly, and the overheated plug tips might cause detonation in the combustion chamber that will blow holes in the pistons. Original equipment "AC" plugs are not the same as "AC-Delco" which is a product made offshore- - - -not from the USA. I'd recommend an equivalent heat range plug from Champion, Bosch, or maybe NGK if you can find something other than AC-Delco in the proper gasket design and heat range.
Dawso #1410048 05/16/2021 3:10 AM
Insomniac
Insomniac
Rock Auto lets you show prices in AUD, so I suppose that means they will ship parts to you.
Rock Auto
I have placed orders with them before and have had good service.
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
Dawso #1410098 05/16/2021 4:49 PM
Champion j12yc or j14yc will do the trick if you can’t find ac. If you need a resister version to calm down radio noise, just add an β€œr” in front of those numbers. They are the correct extended plug with the gaskets. I have run those plugs in my motors for nearly 45 years in both stock motors and modified motors.
J12y, j13y and j14y are the older obsolete numbers but they turn up at flea markets and eBay. Theses will also work perfectly.
Mike
Dawso #1410100 05/16/2021 5:10 PM
"R" prefix plugs also have another important function besides limiting radio frequency interference- - - - -they prevent erosion of the contacts inside the distributor cap and the rotor tip by limiting the current flow across those contacts. A "hot blue spark" that was once the ideal situation is also the equivalent of an arc welder where distributor cap conductors are concerned. Resistor plugs and/or wires prevent damage to critical components while still providing plenty of fire to light off the fuel mixture. "Wire" conductors for ignition systems went obsolete over 50 years ago.
