7 members (GMCJammer51, Phak1, Leo, Tom McGrath, dt235sd, DaveV, Paul_WNC),
106
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Trying to remove the grille on my 46 1 1/2 ton but I have encountered a funny lookin screw looks like a bowtie insert. I got lucky and removed 1 with a flat blade. Is there a special tool and where can I get it. Checked local parts store with no luck. | | | | | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Sounds like you are looking at a "clutch head" screw. Don't know if I have the name correct but that is what I have always known them as. You can get screw driver or insert bit at most automotive stores such as Napa. These screw heads were quite common on earlier Chevrolets. Lots of them on my 1937 1 1/2 truck. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | They are "clutch head" screws. You can buy a full set of screw drivers for these through any of the old chevy parts places for around $16.00, i.e. Chevy Duty, Jim Carter's, Chev's of the 40's. Or I bought a cheap set of tools at Checkers around $19.99 that had three different sizes of these included in with the bit-driver selection. Lastly, if none of those suit your desires, check your local RV store. They are still using these types of fasteners on alot of the newer RV's being made today. | | | | | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | I got the drill insert drivers from Ace hardware.
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
