3 members (dt235sd, UtahYork, 1 invisible),
83
Mod | | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, With what torque do you tighten the screws of the cover of the differential gear? Ask Wolfgang | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Torquing a bolt with a paper or cork gasket under a sheet metal cover isn't a good idea. Tighten the bolt until there's no clearance between the cover and the gasket, and then tighten another 1/6 turn of the bolt head (1 flat of the 6-point bolt). Overtightening can flatten or tear the gasket material near the bolt holes. Jerry
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Just as Jerry said.....Seen too many people torque these bolts and end up with flattening the gasket, then leak, leak, leak.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
