| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | What springs and shocks to use?
I was thinking 1/2 ton, but want to be successful first try if possible
Please advise
Thank you | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Longer springs give smoother ride, shorter give rougher ride, Cannot remove all the short ones however, have to stagger. Removing every other one is helpful. Teflon between leaves helps, plastic pads under tips of leaves also helps.
Ed
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Sell it and buy another truck to suit your needs. Let someone else use it for what was designed for? Just a thought. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Here is the information packet from GM Heritage Center for the 1950 trucks, https://www.gmheritagecenter.com/do...hevrolet-Trucks/1950-Chevrolet-Truck.pdfAbout 1/2 into the packet is the information on springs, length, width, leaves, and spring rate. The spring rate ( rate of deflection ) is how they measure the stiffness of springs. They are measured by adding weight to them. For every 100 lbs the spring is compressed 1 inch, 200 lbs - 2 inch etc ...... Look at the rates between 1/2 and 3/4 ton trucks, then compare sizes. You can go through more years looking for a softer spring that might bolt in. Detroit Spring, and I'am sure others can make softer springs if you have the cash to do so. Removing leaves is also an option, keeping the two top ( longest ) and removing every other one, but you will also give up load caring capacity.
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | My '51 3600 has a flatbed which I suspect weighs more than the standard bed. That said, for years it road Great. I'd run about 30 lbs of air in the rear tires to help soften the ride. It just soaked up bumps and pot holes.
Then....I installed overloads. The ride went all to heck. Unless 1,000 lbs or so is riding in the flatbed and then it's pretty good but not as nice as no overloads. Plan is, if I take it on a trip again I'll spend 30 minutes or so removing the overloads and enjoy the soft life again.
So, if your truck has overloads and you don't use it like a 3/4 ton truck, take em off and lower the rear tire pressure a bit. You might be surprised.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Just for a test, put 100 pounds in the bed near the tailgate. I have a '50 1/2 ton which smooths out incredibly when I tow my boat behind it. I need to put a set of scales on the boat trailer tongue to figure out what I need to add to the rear of the truck when not towing the boat. Rather than putting the weight in the bed I might come up with a way to attach something of that weight where the spare tire used to go which would be easily removable.
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Carl, if you have receiver hitch, make a weighted plug for it. It would be secured, and easily removed when adding the boat. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I thought about that, then subsequently forgot about it. I even had some lead shot lined up to fill a square tube to go in there. The deal fell through on the lead so I gave up for now.
