0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1409188 05/09/2021 4:24 PM
24601
Charlie's headliner (at least the front half) has not been touched since it was installed on the assembly line. I had to remove the back part to install the seatbelt kit ... and it went very well -- I was able to remove it and reinstall it without damaging it.
Back to the front ... Because this is the later '49 and does not have the removable center retainer, will I be able to just gently push it out and remove it after I remove the inner windshield frames?
Something is going on behind it that is causing a rust spot on the windshield frame and I suspect a mouse nest. I want to save the headliner if I can because it's original and its in good shape, other than this rust issue /soft spot.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
My 51 has a 2 part. Once I remove the window frames (includes visors) and screws in the back, mine come right off. I assumed that your old marine corps eyes missed a screw.
24601
Thanks Chris -- I haven't tried yet. What screws in the back? Back of what? Can I just remove the front half, or do I need to remove both front and back?
I am not looking forward to what I am going to find ...
Charlie needs as new home ... frown
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
If it’s a 2 part headliner, I would take out both in one piece. You might wreck the cardboard. Mine has screws holding the cardboard to the metal just above the window. If you need pictures, just ask.
Chris
24601
Chris -- I've removed and replaced the rear piece before but I have not messed with the front half. I guess I will just go at it carefully and hopefully I can intuit my way through it.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
24601
Was able to stop by the garage this afternoon on my way home from the dentist ... Met up with Hambone. Anyway ...
There was no way to save the front half of the headliner. Turns out that it *was* a mouse nest. A big one. Recent, too. But enough that it caused the stain in the headliner and fresh rust on the inside windshield frame. Anyway, with Hambone's assistance, it headliner came out in pieces and I was about to hit the rust with a wire brush and spray the whole thing with rust converter. I think we caught it before things got too far. The headliner was original and and this was the first time the inside of the cab roof has seen daylight since August, 1949.
I saved the visor, though.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I hate rudeness in vermin. Won't tolerate it.
Since you pulled it out, you should consider Formica as a replacement.
Chris
24601
Formica?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Shag. Think of it. Outside the box.
~ HB
1962 Chevrolet C10
1962 Suburban
Originally Posted by John Milliman
Formica?
Yes, I traced my headliner on formica and cut it out. You can find it at home depot for under $60 and it will be enough for headliner and door panels. Easy to clean!
Chris
Shag? It looks like that is what you took out. add a little glue and put it back.
Alec
51 Chevy 3100
24601
Very funny, Alec. Really. Very funny.
laalaa
Why don't you knee me in the groin, too? Make it complete.
nanner
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
John They call them shaggers downunder as well made me laugh
24601
Oh, so *you're* jumping in here, too?? I see... I get the picture ... 1-ton envy getting the best of you all I see. Certainly understandable. But Tim ... you??? oh, I'm crushed that *you* of all people would join in with ... them... Kicking Charlie while he's down.
Sigh ....
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Camp Commandant
Camp Commandant
There used to be a big yellow furball around that farm that would take care of that problem for you. That’s pretty good detective work there.
Shag carpet? Shaggy? The mystery machine......na, too much of a stretch.
For what it’s worth I just purchased some door panels from JC for the 50 that look and fit pretty good. Perhaps you can just replace it at this point with one from him.
~ Billy
1959 GMC 860 | Pictures
Ok now that this thread was Shanghai’d by Tim and Alex, do I need to send a warning shot across the bow before Don jumps in?
Chris
Chris
Like that would ever work...
Moderator
Moderator
2 Offline
How did I get drug into this? You can’t get carpet burns when the shag is on the roof!
Or can you?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Moderated by  ndkid275, Phak1
