| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 52 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 52 | Hello I have a 52 3100 and was wanting to see if anyone has changed out the dash on one of these. I really like the dash in the 55-59 models. Pictures would be great thanks | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think this will require some serious measurement work to confirm fit, anything is possible I guess. I have never seen this switch made so I don’t think there are many pictures. I have scrapped a lot of these trucks for parts and the dash removal itself is difficult. The spot welds cannot be reached to drill them, you end up using a junkyard cut and then grinding to final fit. Good luck! | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | If you can just cut away what you need, to allow the 55-59 section of the dash to fit without getting into the pinchweld at the windshield, it might be doable.
