| | | Forums66 Topics128,209 Posts1,057,462 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I don't mind if I have to order them from a truck parts supplier, but I'm trying to confirm what size the 3 screws are that hold the speedo in on a 1957 truck. I keep seeing ones for cars, and don't know if they are the same size or not.
Thanks! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | pan3lman Go to your local hardware find screws that are probably about an 8,this will just tell you the size. The ones you need to look right I think are phillips...not a 57 guy others will help!!! Do a neat job. | | |
