My regulator unit casting is broken so it cannot be used as a core to order another from Jim Carter. I found a company at https://thisolecoupe.com/windshield-regulator-unit/ that manufactures new aluminum cast units (see pic) which is nice but they want $425.00 each. Does anyone have any other suggestions before I invest in this?
How broken is it? Is it possible it could be repaired?
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
You could also post in the “Truck Parts Wanted” for a working unit or core.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
