3 members (tclederman, DoubleB, Nick in Manitou), 74 guests, and 2 robots.
Topics128,091
Posts1,056,036
Members48,433
My regulator unit casting is broken so it cannot be used as a core to order another from Jim Carter. I found a company at https://thisolecoupe.com/windshield-regulator-unit/ that manufactures new aluminum cast units (see pic) which is nice but they want $425.00 each. Does anyone have any other suggestions before I invest in this?
Chevy-1941-1946-Front
Professional procrastinator
Seems like the going rate. If you are not in a hurry do a search on ebay with an email alert when one gets listed. Patience can pay off.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
How broken is it? Is it possible it could be repaired?
AD Addict & Tinkerer
You could also post in the “Truck Parts Wanted” for a working unit or core.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks.
The casting is broken off on one side where the cogwheel shaft passes through. Don't think that can be fixed.
I just wired the windshield securely shut and mounted the crank handle back on so all would look normal.
I just posted over in the Truck Parts Wanted section. I will also try the Ebay notification trick.
Moderated by  ndkid275, Phak1
