| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Got new hoses for my truck and noticed that they are 1/8" ID versus the old ones that are 3/16" ID. Any cause for alarm? Thanks
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Are you talking about rubber hoses from frame to front wheel cylinder and rear frame to axle Tee? If they are sold by a reputable vendor they are OK. I've not seen brake lines less than 3/16. Those are metal. I assume you are measuring the hole in the fitting that is swaged to hose? Don't think you can get an accurate measurement there unless you use a drill bit as a gauge. Bottom line, I wouldn't worry about it, the pressure will be there.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | These are the rubber hoses. The hose itself is marked 1/8" ID. These are Raybestos hoses, fittings are same as 3/16" ID hose. Thanks for input, probably over thinking it!
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I see now where you got the 1/8. Legit rubber brake hose ID is 1/8, 3/16, 1/4
3/16 steel brake line is the O.D. The ID is basically 1/8, the line having a wall thickness of .028-.035, depending on material and manufacturer.
